idle to high with IAC disconnected
Old Jan 17, 2011 | 01:49 PM
55tpichevy's Avatar
Car: 55 chevy,2000 corvette
Engine: 1990TPI and LS1
Transmission: TH350 W/gear vendor and 6 speed man
Axle/Gears: 85 corvette 3.07 and 2000 vette3.07
I need some idea's. I put a high compression 355 al heads and mild cam under my 305 TPI, added new bosh 26lb injectors. the engine runs good while driveing but the idle when out of gear is hunting from 550 to 1300 and will die, in gear it idles between 570 and 650 rpm I did the min idle adjustment disconnecting the IAC after 30 sec and the lowest idle was 1300 rpm started at 1700 THE wb O2 is12-13 afr in open loop. (no hunting). the directions say to adjust idle to 450 rpm. I did change the bin file to 26lb injectors. any ideas on how to lower my idle? I think that because I can't get the min idle down is why it idles so bad .(the ecm having trouble controling it?) Thanks for any help
Old Jan 19, 2011 | 11:37 AM
55tpichevy's Avatar
Re: idle to high with IAC disconnected
I cleaned the IAC motor and the car was worse, so I went to the chevy dealer and bought a new IAC. It ran or idled better but still surged and died. so for now I just turned the idle adjustment screw in until I had 800 RPM that was enough to stop it from dieing. I still would like some help on why I can't get the idle to do the min Idle adjustment!! Please
Old Jan 19, 2011 | 12:35 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Surging/uneven idle is generally caused by lean AFR. You say it idles well in open loop at 12-13 AFR. Need to figure out what's changing as it drops into closed loop. The key player there is the O2 sensor. Your wide band should reveal if AFR goes lean in CL.
One other cause I've seen for surging idle is EST timing control. The problem has been solved with a new distributor. Also, check wiring to the dist and between the dist and ECM.
Old Feb 4, 2011 | 06:15 PM
55tpichevy's Avatar
Thank you for replying. The engine stays about 14.7 when it goes closed loop. no the problem is at start up ,even when I drive it for 20 min stop the engine for 10 min then start again. It's in open loop when it surges in closed the ECM tries to keep the idle at 650 but it will drop to 580 then up to 700 ,but after driving 30 min the idle will keep a steady 620 when I come to a stop. do you have any idea if the gaskets on the intake tube to pendalum were switch if it could cause an internal vaccum leak ? I'm trying to get my head around why I can't the idle to come down past 1300 on the min idle adjustment, it's like the engine is getting a lot of air with the TB blades closed ? I can use any Ideas you have thanks again Mike
Old Feb 5, 2011 | 01:29 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Did you disable the ECM timing control when setting the minimum air rate?
Old Jun 8, 2014 | 03:58 PM
captainchadl's Avatar
Car: 1987 IROC - Z
Engine: 5.0 TPI
Do you need to disable the timing control when setting the minimum air rate? My problem is that I can't get the minimum idle below 1000rpm with the iac valve disconnected.
specialized
Jun 18, 2022 09:26 AM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
