87 350 Aluminum Heads
Old Jan 17, 2011 | 07:33 PM
bofish52's Avatar
Will a 87/88 TPI manifold bolt to a set of 87 Aluminum heads and are these a good head for mild preformance?
Bob
Old Jan 17, 2011 | 07:48 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: 87 350 Aluminum Heads
Bob
Yes. I like them in modified/ported state. You won't see much of a benefit if they are left completely stock. If they are used then they will probably need new guides or at least guide-liners at the least anyway.
Some pocket porting, machining the guide tops for more lift, a valve-job, and a deck resurfacing would do them a world of good.
When a head needs guide work and valve-job anyway, my preference is to convert them to 8mm LS1 type valves and use Z06 beehive style springs.
There are links to the conversion information in my signature.
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
NinjaNife
Aug 23, 2015 11:49 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
