Big problem!!
Old Jan 20, 2011 | 05:06 PM
Thirdgen82's Avatar
Car: 1982 Camaro Z28
Engine: 350 small block
Big problem!!
I recently ran into a big problem
one day i got home and noticed my car/radiator was smoking and i popped the hood and my fan shroud was melted halfway down causing my new flex fan to hit it and break the radiator was empty but i couldnt find nothin wrong with it, and i cannot figure out why antifreeze was slung all over my motor?? plz help!!
Old Jan 20, 2011 | 05:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Big problem!!
Either a leak in the radiator itself, or in one of the hoses. You can refill the radiator, run the car until it gets hot, and you'll find the leak. Or you can remove the radiator and have it pressure tested (some parts stores will pressure test without removal maybe as well). If the shroud melted, maybe a fan blade dug into a fin and created a leak. Or maybe it developed a leak, thus overheating and melting the shroud.
Old Jan 20, 2011 | 05:26 PM
Car: 1992 RS
Engine: Carbed 350
Re: Big problem!!
Look here:
http://www.austinthirdgen.org/index.php?pid=22
http://www.austinthirdgen.org/index.php?pid=36
Old Jan 20, 2011 | 07:15 PM
wformula91's Avatar
Car: 91 Firebird Formula/92 Firebird
Engine: 5.0/3.1
Axle/Gears: Factory
Re: Big problem!!
also, check your hoses' connections, make sure clamps are tight, etc, ive had that problem before. you also may want to check up on the thermostat, water pump, and other parts like that.
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
overdriv
Aug 20, 2015 03:52 PM
sreZ28
Aug 14, 2015 07:48 PM
