oil pressure
Old Jan 20, 2011 | 04:13 AM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
oil pressure
what is the normal operating oil pressure for a lo3 engine? thats 305 tbi.
Old Jan 20, 2011 | 05:52 AM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: oil pressure
My book says 18 psi minimum @2000 rpm. On my LO3, the oil gauge always stays under 30. Usually about the 1/4 way mark once its warmed up. But I don't think the our gauges are very accurate.
Old Jan 20, 2011 | 02:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: oil pressure
Mine is always 30 or higher - the only time I saw it under was when I was losing oil (a leak I fixed). When cold it will be higher, and should also increase with rpm's to a degree. Mine is about 60 when cold, comes down to 30 when warm, will peak back to 60 when I gun it in park.
It's going to vary alot with individual cars - these factory guages are old, tired, and never worked well when new. You could try a new sender and see if there's a difference. Clean fresh oil and having crankcase full of oil always makes a difference. Remember - check oil cold.
Old Jan 20, 2011 | 07:22 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
Re: oil pressure
the oil pressure gauge in these cars are not accurate. if worried run a known good gauge.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
