is a cfi to crb swap a nightmare??
Old Jan 24, 2011 | 10:10 AM
moondog1h's Avatar
Car: 83 z28
Engine: 305 cfi
want to swap my cfi to cab,what is needed to change ,is it a wiring nightmare or a fairly easy swap,fuel pump,computer,or can all that be bypassed,any info would be greatly appreciated not tryin to build a hot rod 305 just dont like alot of elctronics,thanks doug
Old Jan 25, 2011 | 03:50 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: is a cfi to crb swap a nightmare??
welcome to TGO!
this has been done by quite a few of the members around here (myself included) and you should be able to find answers to all of your questions over here:
https://www.thirdgen.org/forums/carburetors/
most of the wiring can come out, you'll need a new distributor, and you'll have to figure out whether you want to use the stock electric in tank pump or remove it and do a mechanical pump. which trans you have will add to the work, but you should be able to find more details there too
Jorlain
Aug 24, 2022 05:11 PM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
