Cranks but doesnt start!
Old Jan 24, 2011 | 04:11 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Hey everyone, Got another one for ya! The other night I was out at hooters for a friends B-day, the bird was runnin great. I get home, and my girlfriend says she wants ice cream, so we get into my car, turn the key, and it just keeps crankin. Sounds like its about to catch but doesnt. Basically, we ended up takin her car to dairy queen
So far, my diagnosis is that im not getting fuel, when I crank the engine fuel doesnt spray out of the injectors. My injectors are new, fuel pumps new, fp relay just replaced. If I spray Ether into the tbi it starts right up n then dies. SO, That rules out spark. Im looking for posibilities for this situation. So any advice or ideas are appreciated.
Thanks in advance everyone, Matt
Old Jan 24, 2011 | 04:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Cranks but doesnt start!
Heard of VATS?
https://www.thirdgen.org/vats_passkey_system
https://www.thirdgen.org/forums/elec...6154-vats.html
Old Jan 24, 2011 | 06:02 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
I read everything you sent me, and im convinced that might be the problem. I replaced the old steering collomn a couple monthes ago, and swapped out the key cylinder from the old one to the new one. I used butt-connectors on all the wires. When i went to start it the other night i saw a spark from the inside where all those wires happen to be, im wondering if maybe one or two may have come loose and shorted out on each other. All of this is giving me a headache. . . Someone HELP!
Old Jan 25, 2011 | 01:00 AM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
still havent figured it out. Im surprised, nobody's got an ideas? Usually id have 20 replies by now, and at least a couple crazys suggestin i check my compression.
Old Jan 26, 2011 | 01:27 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
UPDATE:
So I replaced the fuel pressure regulator and all the fuses under The dash, and its still not working. I think its an injector circuit problem. Are the injectors wired to the steering column in any way?
Old Jan 26, 2011 | 06:25 PM
jerrya27's Avatar
91 rs is doing this same thing but mine wont crank with the key only by jumping the purple saftey neutral wire
Old Jan 26, 2011 | 08:11 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Originally Posted by Matt1821
UPDATE:
have you checked if ur injectors wires are getting any pulse while cranking it? usually the vats throws a code and usually disables the starter unless the starter relay has been bypassed, there's two fuses for the injectors check them if u haven't done so.
one more Q? do u hear the fuel pump priming when u turn the ignition on?
Old Jan 27, 2011 | 02:47 AM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
I'm gonna use a test light and back probe the injector wires while my buddy cranks the motor to see if I'm getting a pulse to them tomorrow. I replaced all the fuses under the steering wheel compartment but I heard there are a couple more fuses in the engine bay? If so, where are they? And I can hear the fuel pump prime everytime I turn the key. I know the pump is good for sure. The problem has to be somewhere in or around the tbi. I opened up the rails and fuel was during out. So I know there's fuel pumping just not coming out.
Il also check for codes tomorrow, but I don't think there are any.
Old Jan 27, 2011 | 05:20 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
IF you read that first link I posted you will note the VATS module reads the resistor pellet that is in the key and if it is correct , the VATS module allows the starter to turn and the injectors pulse
The fact your engine cranks means the module is reading the resistor correctly ( unless the starter relay has been bypassed) but the VATS module is not sending the fuel enable signal to the computer.
Could be faulty module , could be broken wire between module and computer
Need a special injector test light called a noid light.
Old Jan 27, 2011 | 05:27 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Vats has two parts;fuel and starter
several on here recently have had problems where VATS is reading the key correctly but the fuel enable part of the module is not working so they have a crank / no fire cond
Old Jan 27, 2011 | 02:25 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
so your saying it could be my ecm? I thought that if it was the VATS that the security light would come on?
I could really use a wiring diagram from the steering collomn to the ecm to the injectors.
Like i said, I saw a spark from inside the steering colomn, and im wondering if that spark came from a broken wire that may go to the injectors or ecm/module
Old Jan 27, 2011 | 02:27 PM
jerrya27's Avatar
mine is doing nearly the same thing can im trying to find the ecm and wires for it my self
Old Jan 27, 2011 | 05:14 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
I found some shotty wires that lead into a connector attached to the steering column, they were a little broken so I'm hoping when I replace those it will cure my problems...
Old Jan 28, 2011 | 12:48 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
UPDATE
Fixed all the wiring but still won't start. I hooked up a test light to the injectors and found that while the key is ON and the engine cranking they both have constant power to them, it did NOT blink intermittently like it should. What's going on here?
Old Jan 28, 2011 | 07:50 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
I also have no codes besides an egr code. 54 I think
Old Jan 28, 2011 | 11:15 PM
juanillox8's Avatar
Car: TOO MANY
are u sure? code 54 is fuel pump related (low voltage) with this the car will crank but no start, check the codes again.
Old Jan 29, 2011 | 12:24 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
UPDATE. I hooked up a test light to the injectors and found that while the key is ON and the engine cranking they both have constant power to them,
Where did you hook the light up to ? , injectors have constant 12V on one side from the fuse
UPDATE
You have no injector pulse.Vats may not be supplying fuel enable signal to ECM or module in dist not giving cranking signal to ECM .
Do you have spark?
Old Jan 29, 2011 | 06:10 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
I checked for codes again, and there were none. I guess it was erased when I checked them last time.
Old Jan 29, 2011 | 06:22 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Do you have spark?
There's two wires that go into each connector for each seperate injector. I quickly probed one wire on one connector, cranked the engine and the light stayed on constantly, never blinked. I did the same on the other connector and got the same results. I DID NOT CHECK BOTH WIRES ON EACH CONNECTOR. I was already late for work so I only had a little time to check it out.
How can I check if I have spark without ZAPPING myself?
-Matt
Old Jan 30, 2011 | 05:10 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Update:
Tested the battery and got 11.6V, its low because every time I crank it I lose more and more power... so now I need to get it charged so I can test the injectors. I might have to take it into the GM dealer if i dont get the problem taken care of soon.
Old Jan 30, 2011 | 05:48 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You NEED a " noid" light to test injectors , can be loaned from Autozone or similar
Put tongue on end of spark wire
Remove a plug wire , put an old , good spark plug in the boot end and sit plug on the block / head / intake somewhere.
Should see spark at plug gap when cranking
Old Feb 7, 2011 | 09:23 AM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
I'm taking it into the dealer today to see whats wrong with it. Any guesses?!
Old Feb 7, 2011 | 10:53 AM
whiteboycv67's Avatar
Car: 90 Firebid
Engine: 3.1
Axle/Gears: 10 bolt posi w/4.11s
if you found bad wires in steering column id bet its the ign switch not the the tumbler but the electronic switch itself id replace it first if it doesnt work then it may have burnt something out from shorting but if the batt isnt dying overnight then its not got a constant short if the butt connectors under the dash were sparking theres a good chance your not making proper connection thus code 54 low voltage to fuel pump if theres not enough voltage to fuel system injectors will not spray
Old Feb 7, 2011 | 10:55 AM
Car: 90 Firebid
Engine: 3.1
i could walk you through fixing it yourself if you dont want to spend all that money at the dealer
Old Feb 8, 2011 | 10:48 AM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Well, just got off the phone with the GM dealer. He said it was the distributor. I didnt think the distributor could effect my fuel injectors though?
So how difficult is it to replace this bad boy? and how much am i lookin to spend?
I know for a fact that i dont have a wrench that can get to the bolt on the distributor. Its in an odd placement where i would have to bend one of my wrenches to get to it.
Dont they sell like a flex head wrench or an adjustable one that can be made into an L shape wrench?
Old Feb 8, 2011 | 10:58 AM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Also, Should i buy a performance distributor or just OEM?
Where should I buy it from?
Jerry (GM dealer) said it was my cap, rotor, and coil.
He must be crazy because he wanted me to pay him $789.95 to replace it.
Old Feb 8, 2011 | 02:27 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Ive been looking around at distributors and found a nice MSD ingnition distributor for $315.00. It looks really nice, but a little too pricey and I dont have the time for shipping anyway. I need it as soon as possible. I really dont want to get one from auto zone or o'reillys, i know there cheap (like 100 bucks) but, i know "you get what you pay for" and i want something thats gonna last. SO what should i get and where, and for how much. LET ME KNOW
or do you think i should just go with autozone. . .
Old Mar 18, 2011 | 08:40 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Did you ever get this problem figured out?
bryan623
Mar 22, 2021 06:43 PM
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
