coolant problem.. not thirdgen
Old Jan 25, 2011 | 08:12 PM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
this isnt a thirdgen related problem but there are alot of smart guys around here and I like this board anyway.
to the issue- my buddy has a 97 cobra procharged. while running the guage will show higher than it normally does. And its cold out. The cap on the reservoir leaks and spews coolant as it should above 16psi. While hot the coolant tank is full, however when the car is off and allowed to cool for approximately 3 or so minutes the tank emptys itself. New thermostat. new radiator cap.
Old Jan 25, 2011 | 09:10 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: coolant problem.. not thirdgen
That is what its supposed to do. Hence the name "expansion tank". Notice the cold fill level lower than the hot.
The cap spewing may be due to over filling. If its full cold and needs to expand when hot where else is it going to go.
Old Jan 25, 2011 | 09:41 PM
Nater36's Avatar
its not full cold though... the tank is completely empty... the tank only fills when the car is hot and running
Old Jan 25, 2011 | 09:55 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Then there may be an air pocket in the system. Foords many times have a bleed screw that you open when filling the systems. Look around the T-stat. That could be why it pukes the coolant out and when cools takes it all and is not getting enough coolant and more air.
Old Jan 25, 2011 | 10:01 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Bleed it, if that doesn't work your radiator is shot. When it warms up, feel the radiator everywhere... if some spots are very hot and some are cold; replace it.
Old Jan 25, 2011 | 10:19 PM
Nater36's Avatar
been there too man.. thats the thing.. its baffeling.. gone through three mechanics and they dont knwo either...
what would be shot in the radiator? just clogged? need flushed maybe? or just dented and blocked? ill check that out thanks
Old Jan 25, 2011 | 10:31 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Could it be filling the expansion tank as soon as it started? Or even with it hot and good old aluminum expanding. Maybe there is a bad head gasket or somehow combustion chamber gasses getting in the cooling system. Over heated, warped head maybe.
Did these three mechanics do a block test?
Old Jan 25, 2011 | 10:45 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
It might be clogged, I've had the same exact issues on a Z71 though. The radiator was getting warm in "patches" and cold in other spots. I couldn't unclog it so I bought a new one.
Old Jan 26, 2011 | 01:20 PM
Nater36's Avatar
i suggested a compression test. he is thinking about it. ill have him feel around the radiator
Old Jan 26, 2011 | 03:08 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
He needs a block test more than a compression test. You can get kits at Crapa er I mean Napa.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
fonzie85
Aug 13, 2015 11:50 AM
