fresh 350 will not start
Old Jan 26, 2011 | 09:32 AM
84camaro18's Avatar
Car: 84 Camaro Sports Coupe
Engine: Stock 305
okay so for the last year i've been building my 350 from the bottom up.
this build included a .060 over eagle rotating assembly, lunati cam (lift .468 intake .489 exhaust), edelbrock performer intake, stock 882 heads rebuilt with "z28" springs good to 500 lift. , 72 block, hei ignition, holly 600? carb, new fuel pump etc.
well my problem is i got everything in the car ready to crank and the motor will turn over and turn over but it won't start. every now and then ill here it try but it seems like maybe its not getting enough gas? it back fired through the intake at first and i found out the distributor was 180 backwards so i turned it around and i still cant get it to crank. even spraying starting fluid it still wouldnt crank. im pretty sure i got the timing right? any help would really help asap. im scared to keep cranking on it because of the new cam :/
please help!
Old Jan 26, 2011 | 11:04 AM
camarito's Avatar
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
Re: fresh 350 will not start
you sure your cam is installed right on the timing gear?
the only thing that would keep it from fire with the starting fluid is the ignition, timing, or the cam is completely off
Old Jan 26, 2011 | 11:24 AM
84camaro18's Avatar
Engine: Stock 305
well when i installed the chain i lined the dot on the crank gear to the dot on the cam gear. sound about right? and i took the valve cover off to watch the valves and when the harmonic balancer hit 0 number one piston was tdc and the valves were closed. im lost :/
Old Jan 26, 2011 | 11:29 AM
rdsiler's Avatar
please help!
Sound like you know what you are doing. Did the back firing go away after you rotated the distributor? Do you for sure have the rotor button and the wires installed correctly in the right firing order?
Old Jan 26, 2011 | 11:43 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Lets eliminate the fuel concern by filling the floats with gas. Now check your spark. You will have fuel and spark at this point; it leaves us with bad compression or your timing is off (from experience when a distributor goes in 180 degrees backwards it will jump a tooth or two when you flip it around).
Old Jan 27, 2011 | 04:54 PM
windowrattler's Avatar
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
I had the same problems with my fresh 350 build. My problem ended up being that the fancy 3 postition timing chain set had a 0 and a O. Well i had the marks lined up but they weren't the right ones. Good luck!
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
Bradsaundry
Aug 12, 2015 12:34 AM
gwade12
Aug 8, 2015 08:17 AM
