Bare heads, what valves
Old Feb 2, 2011 | 09:19 PM
89lt1's Avatar
Car: 1989 firebird formula, 1991 z/28
Engine: none LSX! one day, 350tpi
Transmission: none t56 one day, t5
Axle/Gears: 9-bolt 3.45, 10 bolt 3.73
say i wanted to buy these heads bare http://www.store.procompelectronics....oduct_id=37061
what valves should i use there are so many different sizes.
i know diameter head is 2.02/1.6 and stem is 11/32" (there isnt an option for the decimal equivalent of that on summit), but what about overall length, and tip length
what would be a good valve for them.
Old Feb 2, 2011 | 10:59 PM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
Re: Bare heads, what valves
id stay away from those heads they can be hit and miss on the quality search the aftermarket product review for more info. But if you insist on getting them it should tell you if you need +.100 valve stems, otherwise you can get stock replacements 2.02/1.60 valves from summit the sealed power intakes are the cheapest and manely for the exhaust.
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
