87 Trans Am 305 no intake...
Old Feb 5, 2011 | 04:16 PM
sandmancd666's Avatar
I recently purchased an 87 305 without an intake. Is there a quick way to tell if it is carbureated or TPI.... Also I put a stock 305 intake on it as I assume that is what it was... with a quadrajet and I can get it started but runs really rough and will not idle unless I turn the Idle screw all the way up then idles at about 3000 rpm... It floods out at first then clears up but still will not idle... There was old gas in it I have recently replaced as it would not stay running at all before with the BROWN gas. The gas is still a little darker than normal as I was unable to get all of it out... Any suggestions on what I may try to get it idling right would be appreciated...
Old Feb 5, 2011 | 06:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 87 Trans Am 305 no intake...
If it was a TPI car, the fuel pressure would be way way too high for a carb. If you thought the motor was original to the car, the 8th digit of the VIN would tell you what induction system. F = TPI, H = carb
Old Feb 6, 2011 | 02:29 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Is there a mechanical fuel pump on the passenger side of the block?
Orr89RocZ
Apr 25, 2016 08:28 AM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 6, 2015 09:03 AM
Leggman1
Aug 6, 2015 04:15 AM
