my engine ID
Old Feb 6, 2011 | 07:53 PM
ktclayton's Avatar
Car: 84 z28
Engine: 5.7 tpi
Transmission: t5
Axle/Gears: not sure
my engine ID
okayI looked on the back of my engine or what I could see anyways and Im not sure if its my engines ID or not but it says 8004 can someone tell if it is and if its a 350 and all
Old Feb 6, 2011 | 07:58 PM
whiteboycv67's Avatar
Car: 90 Firebid
Engine: 3.1
Axle/Gears: 10 bolt posi w/4.11s
Re: my engine ID
there should be more numbers on the back of the block where the bellhousing mounts up on the drivers side of the distributor and on the front pass side i believe 4 characters for the date code
Old Feb 6, 2011 | 08:01 PM
Car: 90 Firebid
Engine: 3.1
Re: my engine ID
i can decode them but i need all the numbers
Old Feb 6, 2011 | 08:19 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: my engine ID
https://www.thirdgen.org/forums/engi...-question.html
Old Feb 9, 2011 | 07:40 PM
88camaroman's Avatar
Car: 82 camaro sport
Engine: none yet
Transmission: none yet
Axle/Gears: 9in ford no center section yet
Re: my engine ID
a 350 is 010
Old Feb 9, 2011 | 07:49 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: my engine ID
Not all 350's have the 010 casting and not all 010 castings are 350's.
Look behind the driver's side head for a casting number. That can at least determine if it's a 350 or 305 block. On the pad in front of the passenger side head, get the stamped numbers. That can tell a lot more information about exactly what the engine was originally in.
Old Feb 9, 2011 | 10:34 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: my engine ID
3970010 = 4inch bore
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
