hard to start below 50F
Old Feb 7, 2011 | 04:12 AM
babadioum's Avatar
Car: 1991 CHEVROLET CAMARO Z28
Engine: 6 LITER after rebuilding :)
Transmission: 700 R4
Axle/Gears: 3.23 / 9:7:1
It only starts when I press the accelerator when the weather is below 50F or so... Above that temp, no problem whatsoever. If I don't throttle slightly for a few seconds, it stops but once I throttle slightly for 15-20 seconds, it picks up and if I drive it immediately, it idles perfectly OK within 100 yards. Odd as it gets (to me anyway)... ALL sensors/switches have been changed within the last two years and I am suspecting a failing IAC. Any ideas from those of you who had the same problem? Thanks in advance...
Old Feb 7, 2011 | 09:56 AM
irocz28_350's Avatar
Car: 1990 Camaro Irocz
Engine: 350ci
Re: hard to start below 50F
Im having the same problem except I have an '88 L98. I'm thinking its the MAF but yours is speed density, so not sure on your end. Map sensor maybe?
Old Feb 7, 2011 | 10:03 AM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
Pull the spark plugs. They're probably carbon fouled from all the cold starts.
Might be time to replace. A good throttle body cleaning, idle control motor and check all the plug wires and air filter.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
