91 z28 engine wont crank
Old Feb 7, 2011 | 09:12 PM
gmansr's Avatar
Car: 91 z28
Engine: 5.7
first a little history on the car.Someone had tried to steal it from previous owner and messed up the steering column.It has been sitting for 6 years and i just got it for a trade.The vats is good i checked resistance at key to resistance at the wireplug under column its the same.The ign. switch actuator rod is there but rack that holds it in place is busted. I should be able to turn key on and just move rod to engage starter right? I tried that and didnt work next i pulled starter and bench tested,its ok. This is where im stuck im not too keen on the electronics nowadays.(my last project was a '60 El camino).Where do i go from here? Where and how?Thanks in advance for ur help. Btw everything else comes on in the car if that helps
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
92projectcamaro
Aug 6, 2015 01:20 PM
