BACKFIRING FROM BOTH ENDS
Old Feb 8, 2011 | 08:17 AM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
I have an '84 Z28 that will backfire (in the carbuerator) upon deceleration. However, when I drive to work (or Home) and turn off the car; BOOM!!!!!!!! It sounds like a shotgun. This backfire is in the rear. The carb backfires are most likely due to the carb needing a good rebuild. The backfire from the rear is so loud, that I am worried about serious damage if it is not addressed. I am planning on replacing the ENTIRE EXHAUST SYSTEM, but could it be something else?
I
Old Feb 8, 2011 | 12:54 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Re: BACKFIRING FROM BOTH ENDS
I've had it do that through the carb (often called a "sneeze"), and increasing my spark advance fixed it. It was more when Id stomp on the gas though, not on decel so that may be different. Timings a good place to start checking anyway. If you still have the quadrajet, they work better with the advance set to about 6before (with the control wire unplugged) rather than the 0 as suggested on the sticker.
morrow
Jan 13, 2024 12:29 PM
J-money
Jan 4, 2019 09:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
