Single wire o2 sensor to a 2 or 3 wire?
Old Feb 10, 2011 | 06:51 PM
prplestanghazer's Avatar
Car: 92 camaro
Engine: 305 tbi
Transmission: 4l60
lol....i have a 92 305tbi camaro, i have a lt1 cam, and vortec heads, and slp headers and y pipe im installing, its been awhile since ive done any research on tbi....does anyone know how to convert the single wire o2 sensor to a 2 or 3 wire whichever it is? any particular person i should get to burn a chip for me?
Old Feb 11, 2011 | 12:15 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Single wire o2 sensor to a 2 or 3 wire?
The sensor wire of new 3 wire unit connects to your old single wire connection
The other two wires ( usually same colors ) of a 3 wire O2 are 12V and ground; is only a heater so no matter which way around
Old Feb 11, 2011 | 01:46 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
The bosch 13077 is the one I used. You could either buy a pigtail for it or just crimp/solder the wires together each time you change it like i did. Cut the connector off the original sensor, hook that to the white wire (with some extra wire between so its long enough), hook one black wire to ground, the other black wire to one of the on-in-run spots on the fuse box (wire an inline fuse to be safe).
No chip changes should be involved, the operating voltage values are the same as the original.
Old Feb 11, 2011 | 04:49 PM
Car: 92 camaro
Engine: 305 tbi
Transmission: 4l60
the car is mostly stock now.....i have the lt1 cam vortec heads and slp headers(not installed)......id think to optimize the xtra flow and compression a custom chip would be needed.....just askin for any recommendations.......ive been getting them from harris...didnt know if there were better choices for the money, i know the o2 mod doesnt need a chip
Old Feb 11, 2011 | 04:50 PM
Car: 92 camaro
Engine: 305 tbi
Transmission: 4l60
thanks sparky
eightsixseven
Dec 16, 2024 01:50 PM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
Bert87
Aug 23, 2015 03:50 PM
