Calling on valve train experts...
Old Feb 10, 2011 | 08:41 PM
Curious_George's Avatar
Car: '87 IROC, '92 & 99 Corvette Vert.
Engine: L98, LT1, LS1
Transmission: L98 = 700R4
Axle/Gears: L98 = 3.23 G92
I am almost finished with my 350 build for my '87 IROC Camaro. My question(s) concerns the VTG. The valve train consists of the following new parts (Except for lifters):
1.) http://www.lunatipower.com/Product.aspx?id=2005&gid=261
2.) Standard length OE pushrods - 5/16", 7.2"
3.) OE 1.5 ratio stamped steel rocker arms, non self-aligning
4.) 081 heads with Summit screw-in studs. No guide plates, using OE slots in head.
5.) Stainless steel valves are correct length (Same as OE steel valves)
6.) Used OE roller lifters in good shape (Taken apart, cleaned and reassembled).
Note: I have an extra roller lifter that I converted to a "solid" lifter for checking VTG with the proper preload. I also marked the valve stem tip with a Sharpie marker to verify the sweep movement.
With everything assembled, I proceeded to check the rocker arm sweep (With my test lifter) across the valve stem tip. With the lifter on the base circle, the rocker arm is slightly off center toward the intake manifold. At full lift, the rocker arm sweep is toward the exhaust, but more toward the end of the valve stem. See picture for reference.
Everything I have read, would indicate that a long pushrod length will cause this condition. However, I am having a hard time understanding this because of the cam I am using. To get the additional lift that the cam affords, it has to have a smaller base circle than a stock cam. This will place the lifter deeper in the lifter bore. If this is the case, and I am using OE length pushrods, how can my pushrod length be too long to cause the above condition?
CG
Old Feb 10, 2011 | 10:08 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: Calling on valve train experts...
Have the heads are block been milled?
Old Feb 10, 2011 | 10:36 PM
The block was decked 0.02" The heads were cleaned up prior to me getting them, but my guess would be they had 0.01~0.02" shaved off to clean them up.
I am using a 0.041" thick (compressed) head gasket.
Old Feb 10, 2011 | 10:51 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
That's exactly what I was going to ask.
Did you verify your lash adjusting process was completed properly?
How many turns after zero?
Old Feb 11, 2011 | 05:24 AM
Yes. 1/2 turn after zero lash.
CG
Old Feb 11, 2011 | 08:41 PM
thewizard's Avatar
I'd say get one of those pushrod length measuring tools to see what info it has to offer.
Old Feb 12, 2011 | 08:35 PM
After pondering this situation a little more, I have answered my own question (which is usually the case).
Obviously, from my earlier information, my pushrod length is too long. Tolerances add up and you cannot take it for granted that everything will end up as it should be until you measure everything.
My block was decked 0.02". I assume the heads had 0.01~0.02" shaved off of them when they were rebuilt (Bought them rebuilt). I am using a 0.041 (compressed) head gasket. The OE head gasket is 0.028". The difference between the OE head gasket and my head gasket is 0.013" (.041" - 0.028" = 0.13") So, if we add this up 0.02" + 0.02" = 0.04" - 0.013" = 0.027"
What does all this mean? My VTG is off by at least 0.027", which does not seem like that much, but it is enough to throw things out of whack. Factor in my Lunati cam and it is even more out of tolerance.
I made a variable length pushrod today out of an extra OE one I had. I cut the pushrod about 2" from the ball end and drilled and tapped it for a 1/4 x 20 threaded rod about an 1" long. Cleaned up all the edges and assembled it. I adjusted the pushrod for a length of 7.150" (verified with my precision caliper) and installed it. After checking the rocker sweep with the modified length pushrod, it was exactly in the middle of the valve stem.
Now that I have identified the proper length pushrods, my OE rocker arms are now dangerously close to hitting the rocker studs when the valve is closed. When the valve is open, there is no issue. I could open up the rocker slot with my Dremel tool and the appropriate bit, but I am not too crazy about this idea. I am not certain what the long term effects of this will be.
In a nutshell, I need 7.150" pushrods and long slot 1.5 rockers. I am intentionally using stamped steel rockers for this build and may go to 1.5 roller rockers at some point in the future. I don't really care for the additional valvetrain noise with roller rockers.
CG
Old Feb 13, 2011 | 12:59 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
081 heads are tpi, They are meant to locate with self aligning rockers, not the slots.
Old Feb 13, 2011 | 08:05 PM
Well, in this case, the 081 heads I have are built for non self-aligning rocker arms. These particular heads have the "guided" slots from the factory.
Old Feb 13, 2011 | 11:35 PM
thewizard's Avatar
Have you looked into those aftermarket sets of stamped rockers with roller tips? They are less than $100, and normally have elongated slots.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
