This might b stupid but two stroke oil in gas?
Old Feb 13, 2011 | 01:38 AM
Stroke's Avatar
Car: 1992 Camaro RS
Engine: 565 Big Block Chevy
Transmission: RS Jerico 5 Speed
Axle/Gears: 9 inch ford with 3 inch gear
Could you run two stroke oil in the fuel and lubercate the top end of the cylinder to run a tighter oil ring tension to pull more vacume with a vacume pump? It would be a very ratio 1 part oil to 100 part fuel or some thing like that. Whats your take on this
Old Feb 13, 2011 | 03:09 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: This might b stupid but two stroke oil in gas?
If your engine still has the cross-hatching in the cylinders (IOW, the engine is still relatively new), youll already have an oil film on the cylinder walls to begin with. 2-cycle will just smoke, and cause excess carbon deposits on the pistons and valves. As for the rings, what are you trying to accomplish with the engine?
Old Feb 13, 2011 | 07:34 AM
Stroke's Avatar
Car: 1992 Camaro RS
Im designing a Endurance type engine that sees 7000 - 9000 rpm for 2 hours or more. I wouldn't care if it smoked i just want the engine to last. I found some low carbon two stroke oil Red Line Two-Stroke Watercraft Injection Oil (http://www.redlineoil.com/product.aspx?pid=22&pcid=16). Would you still see high carbon build up if mixed it a very high ratio? Would the high revs keep it cleaned out? Could it cause detonation? Could i just be paranoid about it not getting enough oil?
Old Feb 13, 2011 | 01:37 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Will two sroke oil lower the octain in fuel like regular oil will ?
Old Feb 13, 2011 | 06:38 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
There was some discussion about this on www.bobistheoilguy.com last year. I can't comment because the topic didn't interest me. You can search for it in the "Fuel and Fuel Additives" section.
Old Feb 13, 2011 | 09:44 PM
Engine: 355
I know the Mazda rotary guy run it ti help on wear.
1992 Trans Am
May 10, 2023 07:19 PM
Cleotiz
Jan 6, 2018 08:56 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
