Intake manifold swap question
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
So I took off the stock intake manifold and I am replacing it with a holley. What is the reason for the 2 rear coolant ports being blocked off with aluminum squares and only a small hole drilled in them for coolant to flow through. Is that something I should leave or remove? Wish I took a photo of them, anyone know what Im talking about?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Intake manifold swap question
To restrict coolant flow
Just use the correct intake gasket for your engine if it has the restrictor plates built in
Does the Avenger have the rear coolant crossover passage?
( most aftermarket intakes don't )
If not , then restrictor becomes academic as no place for the coolant to flow anyway
Im not sure, Ill have to check it out tomorrow. Thanks for the info.
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Is that the Holley 300-36?
Nice intake youll like it. Makes good torque
86IROC112
Aug 17, 2015 02:00 PM
