88 T/A 5.0 High Idle
Old Feb 13, 2011 | 11:48 PM
hondaracer14's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0 TPI
Transmission: 700R4 w/ B&M Shift Kit
Axle/Gears: 3.18 posi
Hi I have a 1988 Trans Am 305 TPI. It idles at 1500 rpm cold 1000 rpm warm and 700 to 800 in drive. Any tips on making it lower or is that correct? I was messing around with the idle screw and throttle positioning sensor but im not sure. Also i removed the heater diverter valve after removing my A/C and cleaning up the engine bay. I cut the vacuum line running to that and the one from the intake not knowing I wouldnt be able to change from defrost :/. Is there anyway i can fix that? Thanks
Old Feb 14, 2011 | 11:40 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 88 T/A 5.0 High Idle
First off, Welcome to the boards!
To fix the defrost issue, you're going to have to replace the vacuum hose that you cut. This cut vacuum line is also the most likely culperit of your high idle since it's causing a loss of vaccum. Replace that line, should fix both your problems.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
nhra-trans-am
Sep 17, 2015 10:16 PM
db057
Sep 4, 2015 07:57 AM
