Car died, lost all power and negative battery cable is gone
Old Feb 14, 2011 | 09:29 PM
DomesticCheese's Avatar
Car: 1984 Chevy Camaro & 1988 Trans Am
Engine: H/C/I LS1 & 305 LB9
Transmission: T56 Magnum-F 2.66 & Stock T5
Axle/Gears: QP 9" TruTrac 3.70 & Stock 10bolt
I was sitting at a stoplight and i lost all power and the car completely died.
I go to the engine bay, and on the battery there is no negative cable at all. I don't see it loose in the engine bay at all. It still has the negative cable on the side of the battery but the top one is completely missing.
Where does the negative cable come from? I haven't had the car for long and never really looked at it. It's just a near stock carb'd 305.
Old Feb 14, 2011 | 09:34 PM
KnightmareCS's Avatar
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
Re: Car died, lost all power and negative battery cable is gone
One wire comes from the starter, the other comes from under the alternator on the bracket.
Positive (red) goes to starter.
Old Feb 14, 2011 | 10:29 PM
I never knew exactly the way side post / top post batteries worked but a friend explained it to me.
So now I'm simply at a stage of having no freaking idea why I have no power or anything. No click when I try to start, no lights at all. Absolutely nothing
Old Feb 15, 2011 | 12:04 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
well check your fuses
Old Feb 15, 2011 | 01:33 AM
sbcfever350's Avatar
Car: 92 firebird
Engine: Sbc 357
Axle/Gears: 4th Gen 3.42 Zexel Torsen
Make sure both your battery cables are tight at each end my positive cable has come loose a time or two at the starter also could be the fusible link.
BRoss99
Aug 10, 2025 05:08 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
