tranny help please
Old Feb 15, 2011 | 05:54 PM
affliction1's Avatar
Car: 89 chevy camaro rs
tranny help please
my car is buzzing when warm at idle,its coming from the tranny,i lookewd it up and it said a preasure regulator was to blame,but i cant find the part any where can someone give me a link to the part so i know what im dealing with,or a pic and breif crashcourse on where it is and how to change it
Old Feb 15, 2011 | 06:10 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: tranny help please
https://www.thirdgen.org/grinding-noise-low-rpms
Old Feb 15, 2011 | 06:15 PM
Car: 1992 RS
Engine: Carbed 350
I am no tranny expert - not saying that's your issue, just that I found the info.
Old Feb 15, 2011 | 06:30 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The pressure regulator valve is at the front of the valve body, right next to where the filter connects to the pump inlet. It's held in place by a snap ring. I don't recommend removing it unless you have some experience with the process. The valve assembly is made up of 5 peices. If you wish to proceed, please take care not to lose or or mix up the peices. One possible cause of the buzzing noise is also a stuck vane in the pump itself. I recommend servicing the trans and adding 1 bottle of Lubeguard Red to the fluid along with replacing the regulator assy according to the TSB.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
