need help , new 350 wont start
Old Feb 16, 2011 | 11:20 AM
ericg83z28's Avatar
the valves are lashed in the correct order , i have put the crank to 0 tdc on #1 piston and the rotor on #1 tower , the car has fuel and spark , and still wont fire? any suggestions ? timing chain marks are fine aswell
Old Feb 16, 2011 | 12:42 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: need help , new 350 wont start
Did you get it set to TDC #1 piston on the compression stroke? There are 2 revolutions for every 1 complete valvetrain cycle, compression stroke and exhaust stroke - you must be TDC on #1 cylinder on compression stroke, or else you're 180* off on the firing order. Place finger over #1 plug hole and while engine is rotating over you'll feel air pressure on the compression stroke - then line up TDC with balancer timing marks, then where rotor points should be where the #1 plug wire goes, then follow firing order.
Old Feb 16, 2011 | 11:26 PM
ericg83z28's Avatar
ok i will try that tomorrow , thanks for being very straight forward so i could understand u , if it doesnt? then whats the possibilities?
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
