fuel pump is fixed but gpt another prob now
Old Mar 6, 2011 | 07:30 PM
  #51
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Re: not getting fuel help
The green wire with the white stripe on the relay, where does it go to?
Old Mar 6, 2011 | 09:26 PM
  #52
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It runs to the ECM - it's the signal wire to "energize" the relay. The ECM puts 12v+ on that wire, which energizes the relay, and the relay switches power from battery to fuel pump.
Any plans to attend Rims on the River this year?
Old Mar 7, 2011 | 05:16 PM
  #53
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Can I remove all of the green/white wires then since I went carb? I already removed the ECM. And what does the red wire go to? Can I just send key-on power to the green/white wire so the pump is on when the key is?
Old Mar 17, 2011 | 02:35 PM
  #54
robertmoreno14's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
finally dropped the tank, new pump, still not running i think vats is not letting it stay on.
Old Apr 7, 2011 | 12:17 AM
  #55
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
got the pump finally
Old Apr 9, 2011 | 01:15 PM
  #56
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
OK i replaced the fuel pump yesterday and the car starts right up now but it stalls and turns off unless i keep my foot on the throthle what could be that problem. Also it has the check engine light on if that would help.
Old Apr 10, 2011 | 10:06 PM
  #57
Car: 1990 Camaro RS
Engine: 305 TBI
Re: fuel pump is fixed but gpt another prob now
hallelullah the beast is roaring at last. with 7 dollars and a ohm meter, got it running...it sounds angelic. sickr mine had the exact problem, just as yours, i fooled the vats system by adding a resistor of equal value as my key, cranked right up.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
