Self aligning rockers
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Please excuse my lack of knowledge but I was looking at a picture at my heads and I noticed I don't have guide plates. Does that mean these are self aligning rockers?
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Self aligning rockers
It is advised to use Self-Aligning rockers I have seen people use Non self aligning aswell some had issues and some didn't. Play it safe and get SA.
What are you running now,hard to see by the angle of your pic? Any issues with them?
Right now I am looking at some 14011034 bowtie phase 2 heads to replace mine or maybe some dart 165cc s/r but I am not sure what would be better.
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Most factory heads don't use guide plates. If you look closely, you'll see that the push rod holes are narrow with flat sides. The holes themselves serve the purpose of guiding the push rod. Sort of a poor man's, half a** guide plate.
I really just want about 350-400 hp out of my small block 3rd gen so I am doing a lot of research,
Car: '88 Trans Am
Engine: 5.7L TPI
If you plan on 350-400 and you have already decided to get new heads you should take a look at the TFS 21° head they are NICE........ I strongly suggest a bigger camshaft.
Right now I have a 355 with a 500 lift cam. I want it to be fairly mild and a budget build. I think I may have found my solution I just need a new manifold. and Yea I know bigger cam and other happyness but with my 4 motorcycles costing me and my wife back in school I really cannot afford more than 1000 installed for new heads.
here is what I am thinking http://cgi.ebay.com/ebaymotors/NEW-C...Q5fAccessories
Car: 87 IROC Z28
Engine: 355 cid TPI
Even for a good set of heads, the Performer RPM should be plenty of manifold. Atleast up to 6,500 rpm. With your cam and even decent heads, I dont see you making power too much past that. The next step in manifolds is the Victor single plane style. The single plane is really just for high rpm power and will take away mid range torque. You will find that a good set of heads will make all the difference in the world with your current setup.
Car: 87 IROC Z28
Engine: 355 cid TPI
Oh! LOL Of course. Vortecs are a good performance value.
New2Chevy
Sep 28, 2015 12:35 AM
