Solve my problem
Old Feb 21, 2011 | 09:42 PM
jcon104's Avatar
Solve my problem
Ok...here it is. When my t/a hits about 3500 rpms seems to miss. It wont miss though if i were top sit and rev the exhaust to the same rpm only seems to occur while driving. The cap rotor and 8.5 mm plug wires are new. The carb was just rebuilt and tuned. Currently running bosch platinum 2's. I was thinking possible the coil going bad.
Old Feb 21, 2011 | 11:23 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Re: Solve my problem
Try adding a ground wire from one of the two bolts that mount the coil and attach the other end to where the braided ground strap is. And just so you know we have a specific section for everything and you tend to get better advice in the correct section. This question belongs in the tech/ general engine section
Old Feb 22, 2011 | 12:22 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
could be a coil problem and engines react different when under a load in gear.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
