before i start
Car: 1983 Trans Am
Engine: Lu5
Transmission: TH700R4
before i start
My trans am has not been running for about 1 year and before I start restoring it, I want to make sure the engine block is not cracked or there is anything major wrong with it, but I'm not sure what to check or how to check. Any tips on things to check? Any ideas appreciated
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: before i start
many cracks/issues can't be seen - if you think there is a reason for it to have a crack in the heads or the block, then you need to have it checked at a machine shop.
Re: before i start
Check that the fluids are full (and stay that way if you have to fill them), the gas is fresh, the battery is charged, and the key turns.
Think of it this way: let's assume you "check" "everything", and you find .... "something". What will you do differently?
Exactly. Your next post will be something like, the block is broken in half, can I run it anyway? and the answer will be, try it and see. Whaddya got to lose?
Either it's cracked or it's not. All the "checking" in the world won't change that. Either it'll work or it won't. Go find out.
92camaroJoe
Aug 13, 2015 06:07 AM
