carb help please
Old Feb 22, 2011 | 08:44 PM
affliction1's Avatar
Car: 89 chevy camaro rs
carb help please
i have an 89 camaro completely carb,with an 91 305 vortec block,edlejunk 600 carb ,my buddy told me i need a fuel return line,but it hasnt presented any problems to me, so what is the point of it and should i install one...?
Old Feb 23, 2011 | 08:18 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: carb help please
Only if you are using a bypass style fuel reg that uses a return line
Old Feb 23, 2011 | 12:00 PM
my regulator only has 1 inelet and 1 outlet so i dont need it right?
Old Feb 23, 2011 | 12:07 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Are you using the in-tank fuel pump?
Old Feb 23, 2011 | 12:24 PM
im using a 4-7 psi inline pump
Old Feb 23, 2011 | 12:27 PM
Car: 1992 RS
Engine: Carbed 350
Then no need for a return line.
But let me ask ... did you remove the in-tank pump and install a carb pickup?
If not, don't be surprised if that external pump doesn't burn itself out - it takes alot to draw fuel through a dead intank pump and that strain will most likely kill your external pump eventually.
Old Feb 23, 2011 | 02:10 PM
nitrous87's Avatar
Car: 87camaro 357ci
Engine: xe294,scat crank,6" rods,Dartheads
Transmission: th-350 3000 stall
Axle/Gears: 4th gen rear 4.10 gears
I hate those in line electric pumps. I went through 3 in one year in my Lifted C10 because I didnt have a return line. I say go with a manual 110GPH pump from Summit. Only $50, you dont need a regulator or return line, and it supports up to 500hp.
Old Feb 23, 2011 | 03:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You may not be able to mount a mechanical pump on a Vortec block.
Old Feb 23, 2011 | 06:06 PM
nitrous87's Avatar
Car: 87camaro 357ci
Yea your right. I read somewhere that you can buy a kit that allows you to mount one, you just have to drill the hole in your block for the fuel pump pushrod. It sounds like kind of a hassle but may be worth looking into if you hate electric pumps as much as I do.
Old Feb 23, 2011 | 09:16 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by nitrous87
I hate those in line electric pumps. I went through 3 in one year...because I didnt have a return line..
Obviously had something wrong with your setup then
The low pressure pumps that deadhead to the carb don't require a return and run forever
( think Holley Red / Blue series )
Old Feb 23, 2011 | 10:49 PM
nitrous87's Avatar
Car: 87camaro 357ci
I had good fuel pressure every time I changed to a new one. Then sure enough about three months later it wouldnt start and I was only getting about 1 1/2 psi. After the third pump I said screw it and bought a mechanical 110Gph pump. It has kept a consistent 7 to 8 psi going on 2 years now with no problems. The electric pumps I was buying were cheap autozone Spectra pumps, that might have had something to do with it. Having a return line will make the pump quieter, last longer, more consistent fuel pressure, and colder fuel for the engine.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
