"sticky" idle control? 350TPI
Old Feb 23, 2011 | 02:29 PM
alistair's Avatar
Hey guys, you always have the answer when I have a problem so I just know you can help me again!
I have an '88 TA with the 350 TPI. It is great. BUT.... The idle speed sticks too high. Like 1200-1300 RPM. If I blip the throttle it drops right down to about 600-700 RPM and stays there OK.
Then I drive away and when I stop next its the same.
If I am cruising in slow traffic it gains on other cars and I have to ride the brake pedal or it will pull away.
I have no error codes and the engine check light is off.
It has been like this a while but getting worse.
Its really noticeable when you try stop, you have to take it out of drive to get full braking!
Old Feb 23, 2011 | 06:57 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: "sticky" idle control? 350TPI
I would check the throttle body to ensure it's opening & closing smoothly, i.e. without the cable binding or the throttle body being obstructed.
If everything is ok with that, check the Throttle Position Sensor (TPS). It may be malfunctioning and need replaced. The procedure to set/check it can be found here: https://www.thirdgen.org/tpimod2
Hope this helps.
Old Feb 24, 2011 | 12:31 AM
alistair's Avatar
thanks I'll try that.
eightsixseven
Dec 16, 2024 01:50 PM
mike40sm2
Sep 1, 2015 02:15 AM
Dialed_In
Aug 20, 2015 01:45 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
