Leaking Fuel by the gas cap, Help!
Old Oct 28, 2010 | 11:08 AM
Zeuxis's Avatar
Hi Dear Users..
I have a leak of fuel, by the gas cap, of my camaro rs 92, i replace the gas cap, thinking that it is the problem, and not, the leak still, any ideas? what can i do?
Thanks...
Zeuxis.
Old Feb 10, 2011 | 07:27 AM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
Transmission: 700r4 stock
Re: Leaking Fuel by the gas cap, Help!
I'm having the same problem has anyone found the solution or idea
Old Feb 10, 2011 | 09:13 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
wasn't there some sort of recall on filler necks???
Old Feb 10, 2011 | 09:23 AM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
91-92 year models had the recalls but hey that don't mean that the 89 don't have a problem I just had my FP replaced and wondering if the filler neck is cracked is there a easy way to check it?
I only noticed it after the tank was FULL
Old Feb 10, 2011 | 09:30 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Are you over filling it?
trying the best you can to get every drop inthe tank you can, you can put in to much, where it will come out the vents and up the filler neck on a turn.
Old Feb 10, 2011 | 02:17 PM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
yes as a matter of fact I have been discussing this with the guys that I work with and yes I did fill up and then kept trying to fill the tank after the pump kept cutting off and stopping. Do you think this is the problem? IF so will it go away after I drive awhile or have I screwed something up. and last but not least what is the OEM part# for the gas cap I don't think that the one on my car is orig.
Old Feb 10, 2011 | 02:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Shouldn't have screwed anything up - except losing some gas due to overfilling. It's quite possible you have a leak in the filler neck - especially if anyone has ever changed the fuel pump by dropping the tank - you have to bend the filler neck very carefully in order to get the tank out, and sometimes folks bend it too much too fast and can create a leak.
If I found a filler neck leak, I'd sand all the gunk, rust, etc. away from the area, and try some of that marine stuf that's gas-proof - comes in a tube, should adhere to clean bare metal, and is fuel-proof (used on boats with fuel leaks all the time). Won't cost you anything but an hour or so, some sandpaper, and maybe $10 for that stuff - worth a shot before dropping the tank and having a shop weld the leak.
Old Feb 10, 2011 | 03:17 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
If your filling it to much, Im sure it will find a way out with the lvl higher then it should be.
Figure out your typical gallon usage between your typical stops for gas and go by that instead of cramming it full. Like I only buy 5gal of gas at a time. And stop as needed. V8, V6 car same thing, just more stops with the V8
Old Feb 10, 2011 | 03:35 PM
Car: 1992 RS
Engine: Carbed 350
FYI - your tank holds just over 15 gallons when empty. So, even at empty and coasting in to the pump, 15 gallons even will be a "fill-up". I usually run mine to 1/4 tank, then fill 10 gallons in - never quite "full", but close enough. Besides, at $3.20 a gallon and rising (I take 93 octane), a $32 hit is about all I can stand at once
Old Feb 11, 2011 | 05:34 AM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
yeah I put a new o-ring on the cap and drove it awhile then park on a hill leaning toward the drivers side and no leak. I guess I'm used to my other vehicles taking 16-34 gallons to fill up. thanks everyone for your replies.
Now on to the next problem: I have a real bad skip but only under hard accel. just cruising it's fine. some times it (looks) like there is some arching between the wires or do I just have them too close to some metal. (have used three diff. sets of wires) xacts,msd's,and (napa) beldan's. Harold our advance auto expert (he really knows his stuff) said to check engine ground straps any ideas? is he right?
Old Feb 11, 2011 | 07:24 AM
banker's Avatar
Car: 87 TA
Axle/Gears: LSD
Don't come to the UK, it's about $100 to fill up
Old Feb 11, 2011 | 07:49 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Spark will take the path of least resistance to ground, and even if that means coming through the rubber insulator on the wires or shooting out the side of the coil it will. if it doens't want to travel out the end of the plug like it should, something is bad in that chain.
Time for a full tune up, plugs, cap/rotor, wires.
Old Feb 11, 2011 | 10:09 AM
Car: 1992 RS
Engine: Carbed 350
If you see arcing anywhere in the ignition wires, they are bad - even if new. Plug wire manufacturers don't test the wires after they have been cut to length, they only test the entire reel of wire. Try another set of wires, definitely another brand - maybe a different store like NAPA that carries different brand than Harold.
On the grounds - you have
1) neg batt cable to engine (usually alternator bolt)
2) groundstrap from rear pass head to firewall
3) small ground wire from neg batt terminal to fender
Make sure all make clean connections - maybe sand dirt/grime/paint at firewall and fender and alt bracket.
Old Feb 11, 2011 | 12:30 PM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
best wires? advance,autozone,napa,oreilly's?
Old Feb 11, 2011 | 01:26 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
you want good spiral core wire set, or if you need to go cheap, you get an Accel uni super stock kit for $20-25 where you cut to length n crimp your own ends.
Old Feb 16, 2011 | 08:57 AM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
this is what I plan to do: dist cap,rotor,8.5mm spiral core wires (oem),a.c.delco plugs (r45),lucas fuel treatment,throttle body cleaner, air filter, tps, and that should be all it needs is there anything that I missed
Old Feb 16, 2011 | 09:22 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
fuel filter
Old Feb 16, 2011 | 02:46 PM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
fuel filter, ground straps and possibly fuel injectors btw what are the best injectors for 305tbi ?
thank you all
Old Feb 17, 2011 | 02:10 PM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
bump
Old Feb 17, 2011 | 02:54 PM
Car: 1992 RS
Engine: Carbed 350
If you haven't ordered wires yet, Taylor-Made makes nice wires, and they come in many cool colors - they are cut-to-length so you get the right fit - had mine 4 years now and no issues at all out of them.
Old Feb 18, 2011 | 05:39 AM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
thanks, (taylor made) never heard of them but might give them a try.
Old Feb 23, 2011 | 03:57 PM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
Hey got problem I tried 4-sets of wires Xacts,stock,MSD 8mm (advance auto), and 7mmBeldans (NAPA) and all them did the same thing they arch some one told me that if the engine wasn't grounded correctly that no matter what wires I use that I would mess them all up
Is this true? I see the fire/spark (pretty and blue) jumping out near the dist. and in the middle of the wires on both sides of the car
89 305 tbi 700r4 thsi is wierd 4 sets from 2 places supposedly everything is stock. the PO said they took the 305 out and put in a 350 I thought adn still think that he is lying but just in case he's not does it make a diff?
Old Feb 23, 2011 | 04:21 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Should start a thread of your own just about this topic and run down over everything again. But bad engine grounds will do funny things.
Old Feb 24, 2011 | 05:29 AM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
thanks for the advice and I will do it.
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
wayshegoes
Aug 17, 2015 12:00 PM
