Sitting forever
Old Feb 23, 2011 | 10:05 PM
mnwildpunk's Avatar
Car: 87 Camaro sport coupe
Engine: 2.8L its so cute!!!
Transmission: Automatic
Axle/Gears: ???
Sitting forever
First off I tried to find a similar thread but was unsuccessful I know it has to be here somewhere. I have a 87 Camaro that I haven't even seen it in two years. I parked it up north until I had time to deal with it. That time has come and I am wondering what I should prepare for? What maintenance should I make sure to do other then change the oil and filter? My uncle who houses the car said he got in it one day and smelled something dead so how do I remove that smell (after I remove the carcass ASAP?
Old Feb 23, 2011 | 10:32 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: Sitting forever
Well if it hasn't been ran in those two years I would change out all the fluids and check for any animal damage. As for the smell if it was something small it will probably be gone, but if it was something big than you will probably have to change out the interior.
It is a gamble though, I just brought my buddies 79 Caddy home after being in a field for 5 years and there was nothing wrong at all. He put Bounce dryer sheets all over in the passenger and trunk areas and apparently animals don't like them lol.
Good luck!
Old Feb 24, 2011 | 01:43 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Sitting forever
Put Seafoam in the gas tan per directions to clean out the varnish that by now the gas has turned into.
Mice love cars, more than we do - tear into the dash and vents, and you'll find your smell. You'll need to look at all wiring cause to a mouse a wire is like steak to us.
Old Feb 24, 2011 | 02:45 PM
mnwildpunk's Avatar
Axle/Gears: ???
Re: Sitting forever
Ya I put dyer sheets down burt i guess not enough LOL thanks for the info
Old Feb 24, 2011 | 03:22 PM
nitrous87's Avatar
Car: 87camaro 357ci
Engine: xe294,scat crank,6" rods,Dartheads
Transmission: th-350 3000 stall
Axle/Gears: 4th gen rear 4.10 gears
Re: Sitting forever
I always pull the spark plugs and squirt fogging oil in all the cylinders if its been sitting a while. It also gives you a chance to clean and gap your plugs.
Old Feb 24, 2011 | 10:32 PM
89Camaro89MI's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Re: Sitting forever
Yeah, gas congeals (i believe is the term) over time when undisturbed. Syphon anything you've got out of your tank and get it out of the lines, too, if you have the means. That would mean disconnecting your carb/tbi etc and pumping air in there. 2 years isn't all that long, but make sure you put some over the counter cleaner in your tank with the fresh gas.
The big issue I've heard of is fuel line problems. In the future, invest in gasoline storage additives if your car is going to sit.
Old Feb 24, 2011 | 10:33 PM
Car: 1989 Camaro RS
Engine: 305 TBI
Re: Sitting forever
If the smell is on the carpet, pull it out and take it to a DIY car wash sprayer with some pet odor carpet shampoo.
Linson
Oct 24, 2025 02:00 PM
RS Reaper
Oct 17, 2018 07:52 PM
jrdturbo
Mar 31, 2016 02:58 PM
David Frans
Oct 31, 2015 08:12 PM
mfp189
Sep 27, 2015 09:25 AM
