lets test your knowledge!
Old Feb 24, 2011 | 01:34 PM
mackay's Avatar
Car: 87 Camaro LT
Engine: 2.8L
Transmission: Manual
OK, so I'm only asking because I know you guys will be able to help me with this. I have looked through the forum and although there are many people who have a high idle, nobody seems to have exactly the same problem as mine.
So, I've recently had quite a few problems with my car ( jerking when driving, stalling, not starting) and I traced it back to a coolant fan relay and the fact that the idiot who owned it before me never had the oxygen sensor hooked up.. ) so now that I have the car running it runs great except for a high idle. it starts up and idles properly, and then once I have driven it for a few minutes the idle goes up really high (1800 to 2300 rpm) which causes the service engine light to come on and then goes off shortly after I am in motion again. I have looked up the code and it says vss (which can also be set off from a high idle, anything above 1500 for more than 4 seconds so I'm thinking that's the only reason). what could be causing such a high idle? it would be nice to get rid of this little issue!
Old Feb 24, 2011 | 01:40 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: lets test your knowledge!
your the one blowing it so far
No profile info on the left or a sig to help clue anyone in as to what you got, as you didn't say a word in your post about your car's info.
Old Feb 24, 2011 | 04:10 PM
mackay's Avatar
Car: 87 Camaro LT
Engine: 2.8L
good point, sorry about that. haha. i'll update that shortly. for now:
1987 camaro LT 2.8L, manual transmission.
Old Feb 24, 2011 | 04:41 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
You traced a driveability problem back to a bad cooling fan relay? And now your thinking idle and vehicle speed are connected? I think you need to do a little more research... In the mean time check for a vacuum leak and make sure the idle air control is working properly.
Old Feb 24, 2011 | 05:33 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Then you should be posting in the V6 section to get the most help, what its for.
RedLeader289
May 28, 2019 01:47 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
drumstixer
Sep 29, 2015 03:02 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
