WB trouble shooting
Old Feb 25, 2011 | 09:52 PM
95 4x4's Avatar
Car: 1995 Chevy 4x4
Engine: 355 cu. in. Vortec / TPI / MAF
Axle/Gears: 3.73 Limited Slip
WB trouble shooting
I have an LM-1 WB an was hoping some one here had some knowledge with this unit . First off the unit was working okay was having some connectivity with TunerPro . The 9V battery was dead so i put a new one in an was gonna do a update an reset my settings . Went to the site downloaded the latest version an picked the latest firmware to install . Had the serial cable hooked up went to LM program an turned on LM-1 , selected update firmware an started to install , it showed an error so quick i think half way thru . I was not expecting it an it went away so i could not see what it said . Shut things down an went to try again now it won't detect the serial cable ? So next i went an inserted the power cable to see if it will turn on an that does not work also ? I find it very suspicous that the unit went bad just like that any help or suggestions greatly apprecieated .
Old Feb 26, 2011 | 12:46 PM
95 4x4's Avatar
Car: 1995 Chevy 4x4
Re: WB trouble shooting
After some or alot of searching i guess i should not have done the firmware update . The newer version corrupts the older version some how an then you get the blank screen like i have . What is recommended a factory flash does anybody have the software so i can do the factory flash myself instead of sending it Cali for the re-flash ?
Old Feb 26, 2011 | 03:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Would be better to post this in the DIY Prom or DFI & ECM section.
Old Feb 26, 2011 | 04:11 PM
95 4x4's Avatar
Car: 1995 Chevy 4x4
I was gonna do that first but i changed my mind an put it here go figure LOL tks
Old Feb 26, 2011 | 07:28 PM
Cflick's Avatar
Car: 87 Suburban 2500
Engine: 455 Wildcat ( somewhat modified ))
Transmission: TH400 ( for now )
Axle/Gears: 4.10 ( for now )
I'd NEVER recommend a firmware upgrade unless you NEED it !
When a firmware upgrade goes bad, you are truly screwed.
That can't be fixed in the field, even by the factory.
Old Feb 27, 2011 | 04:40 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Id contact innovate, and see if they can help. Sounds like the firmware is corrupt, and it wont boot properly anymore.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
meeklay812
Oct 1, 2015 03:46 PM
3.8TransAM
Sep 27, 2015 08:37 PM
Lmancha96
Sep 25, 2015 08:11 PM
