Alright, annoying idle and I've noticed it in a couple other older cars
Old Feb 25, 2011 | 10:58 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
With the car in drive it idles AROUND 600 when up to operating temp. But the annoying part is that it doesn't operate at 600 steady. It's anywhere from 740-690 so there is some noticeable rumble and I can watch the tach fluctuate slightly and I can get a video if you'd like. I'm not sure what would cause this. It's a 90 Formula with an lb9. IAC valve is new and adjusted according to the manual.
Thanks to anyone with ideas.
Old Feb 27, 2011 | 01:46 AM
mikeirocz1's Avatar
Car: 91 RS and 88 IROC-Z
Engine: 305 TBI and 383 Carb
Transmission: 700R4/2200 stall & 700R4/3500 stall
Axle/Gears: 3.42 posi and 4.11 posi
Re: Alright, annoying idle and I've noticed it in a couple other older cars
throttle position sensor maybe.
Old Feb 27, 2011 | 04:34 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Its an old car, with an engine thats got some miles on it, so it wont idle as smooth as it did stock. Also, the older ECMs didnt have very sophisticated idle controls like the newer models, so they cant control the idle speed as precisely. Newer computers also use the fuel and spark advance to control the idle speed in addition to the IAC (or e-throttle), so they idle much more smoothly.
Also, as for the tach speed, its likely to be off. Youd need to use a scanner or an external tach to get the true idle speed.
Old Feb 27, 2011 | 07:33 AM
Mr Froman's Avatar
Yeah the scanner is what I used to see the actual idle speed (740-690 RPM). And yeah, I can understand how the older technology could be the cause.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
novaderrik
Aug 10, 2015 12:44 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
