sensor question
Car: 1988 firebird formula
Engine: 5.7 TPI :)
Transmission: Auto :(
Axle/Gears: 9 bolt LSD
sensor question
pulled a code for my maf and tps having low voltage or low input or something along those lines. i got codes 22 and 34. does that mean i have to replace them? thats what i did on my last camaro and it fixed the problem, just wondering if there was another option.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: sensor question
TPS can be checked with a digital volt/ohm meter - a search will yield you the resistance levels you should have. But in the end I think it has to be replaced if it is bad.
MAF can be cleaned sometimes - auto parts store sells MAF cleaner and throttle body cleaner - might try it, won't hurt and cheaper than a new MAF.
9192camaro
16
Feb 3, 2019 12:21 AM
