Replacing cracked block for other used/unmachined block. What risk?
Old Mar 1, 2011 | 02:22 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
O.K.
My V6 block is cracked in the cylinder wall number 5. Previous compresion test was 118 psi. (132 psi putting oil in that cylinder). Then, I assume that the rings are in good condition (168 psi. in the others cylinders).
If my block has 130.000 miles and I replace it with other similar block with 30.000 miles only, without any machine job (no bored, honed, fluxed, etc.).
(I mean a homemade cheaper job).
What could be the risks?
How does the rings know that they are running into other cylinder walls?
2010 emission test was:
HC (ppm): 63
CO (%): 0.33
NOX (ppm): 612
PLease help me with yours opinnions and advice,
Thanks,
Denis V.
Old Mar 1, 2011 | 02:38 PM
Guest
Guest
Posts: n/a
Re: Replacing cracked block for other used/unmachined block. What risk?
The rings are not going to seal properly. They mate to the bore, more so the diameter. This happens pretty quick on startup with new rings and a prepped cylinder. At the very least, you should replace the rings. If there are places near you that sell a hone, buy it and hone it yourself.
Old Mar 1, 2011 | 03:24 PM
torque_is_good's Avatar
you're already going to have it apart which means a gasket set. At that point, you should at least hone the cylinders and re-ring the pistons.
It just makes good sense
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
lakeffect2
Aug 23, 2015 08:44 AM
BBSDesigns
Aug 11, 2015 07:39 PM
rithsleeper
Aug 11, 2015 07:55 AM
