If You're Car Wont Start & You Think Its You Fuel Pump Check
Car: 1986 Camaro
Axle/Gears: 411
Your Ignition Control Module 1st, Its Right Under The Distributor Cap Its Easy To Get To & Disconnect. Take It In To Autozone & Have It Checked, Its Easy & Its Free To Get Tested, & Also Cheap & Easy To Fix. If You Change Your Fuel Filter & Fuel Pump & That Doesn't Work You Just Waisted Time & Money Especially If You Paid Someone To Put It In, Just Some Advise! (It Happened To Me) LoL
theshackle
Mar 5, 2017 06:37 PM
