Where would the ID numbers on a 1986 350 be?
Old Mar 4, 2011 | 11:52 AM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
My friend has a motor in his 1970 c10. Said it came out of a 86 silverado. Where are the numbers on it and what should they be if it is a 350.
Old Mar 4, 2011 | 12:01 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Where would the ID numbers on a 1986 350 be?
Rear of block, driver side, just below head. They are really hard to see, a mirror helps, along with a cleaning brush and some degreaser. Once you see where they are, you can clean that spot (not hard to get hand in there, harder to get head in there to see), then use a mirror to see numbers, then just type numbers in google or search "SBC block numbers" and look 'em up.
Some later blocks actually had "5.0" or "5.7" there beside the actual casting number, but best to get the casting number to really know what you have.
Heads make or break a motor - head castings under valve covers, between valves - get those to know what heads he has.
Old Mar 4, 2011 | 01:12 PM
Axle/Gears: G92
thanks, Ill check it out. I don't care about the heads they won't be used I do care about if its a roller cam or not. I am looking for a roller block.
Old Mar 4, 2011 | 04:48 PM
Guest
Guest
Posts: n/a
No need to look for numbers then if it is an 86 block, those did not have a roller cam.
Old Mar 4, 2011 | 05:20 PM
Axle/Gears: G92
I read 86 was the first year roller cam in the trucks?
Old Mar 5, 2011 | 10:21 PM
Axle/Gears: G92
Old Mar 5, 2011 | 10:50 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
GM did not make any small block roller cam blocks until 1987, for anything.
Old Mar 7, 2011 | 06:28 PM
Axle/Gears: G92
89 corvette will be a roller correct?
Old Mar 8, 2011 | 08:17 AM
Axle/Gears: G92
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
Pilotrick50
Sep 2, 2015 12:48 PM
michealleger
Aug 26, 2015 03:29 PM
Eric-86sc
Aug 24, 2015 09:01 PM
armybyrd
Aug 10, 2015 09:23 PM
