Compression/Octane
Old Mar 4, 2011 | 08:04 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Compression/Octane
I'm getting alot of pinning/detonation at WOT over say 4000+ RPMs. The car was dyno tuned but it always pings at higher RPMs at WOT. Tune has 8* base timing and 34* total timing. I have a WB O2 gauge and it doesnt go lean up top even at WOT. I was told by my engine builder that it was a 10.56 compression engine. Tonight I put the numbers in from my build sheet into a Compression calculator.
cylinder diameter - (4.040)
stroke length - (3.750)
number of cylinders- (8)
chamber in cc's - (63)
pistons- - (-6.8)
gasket thickness - (.041)
displacement - (385 cu. in.)
it comes up with a compression ratio of ........ 11.05739
So my question is what octane fuel does a 11:1 engine call for?? I've been running 93 octane with 34* timing and i'm pinning away!!!!
Old Mar 4, 2011 | 08:14 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Compression/Octane
Take a couple of degrees out of the total timing and see what it does. You may have to bump up the octane a couple more numbers to keep it from pinging.
Old Mar 4, 2011 | 08:16 PM
Car: 89 Formula 350
when I went down to 29* total timing I didnt hear it ping. I guess I'll be adding some high octane fuel to my fuel.
Old Mar 4, 2011 | 08:19 PM
oscarfromla's Avatar
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
Also, you may need to look at dynamic compression, not static. I've heard that dynamic compression needs to be at around 8.5:1 for 91 octane, so you may be able to go a little higher for 93. Not too sure how you'd use that info but I know dynamic compression affects pre-detonation more than static.
I heard of a guy running 12:1 static compression on 91 octane because his dynamic was at 8.7:1
Old Mar 4, 2011 | 08:33 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Not an exact answer, but educational for about a 10 min read---
https://www.thirdgen.org/forums/theo...legal-gas.html
https://www.thirdgen.org/forums/tech...78-octane.html
Old Mar 4, 2011 | 08:46 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
A little primer
http://members.uia.net/pkelley2/DynamicCR.html
