Takes 15 minutes to start
Old Mar 6, 2011 | 06:24 PM
Rhett86IROC's Avatar
Car: 1989 RS
Engine: LO3 TBI
When I attempt to start my 86 IROC it will turn over turn over turn over, Start finally, then it will die, you have to repeat this 20 times, before she stays running.
Old Mar 6, 2011 | 07:55 PM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Re: Takes 15 minutes to start
sounds like a fuel issue.
Check pressure.
Old Mar 6, 2011 | 08:08 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Does the fuel pump prime when you turn the key on? Put ear against tank and listen while someone turns on key. If not, bad fuel pump relay - replace.
If so, maybe have clogged filter - should repalce it anyway unless you've replaced it in the last 2 years.
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
mustangman65_79
Aug 8, 2015 12:07 PM
