new guy needs help, tpi breaken up on top end...
Old Mar 9, 2011 | 03:08 PM
Guest
Guest
Posts: n/a
(copy and paste from a chat with buddy)
Hey all, new guy here,
My beast of the night is a 1988 IROC-Z, stock L98.
This problem just started yesterday.
ok, so at wot around 4500 rpm ( in 2nd ) the car starts to...-slightly- break up or feel like it, then at wot in 3rd around 3500 you can feel it breking up....( I think it gets worse when holding wot, ill do a back road test again today... )
---first gear its all fine---
-thanks guys, need to get this fixed before me and my buddy put a king of the hill tpi on it.
; P
Old Mar 9, 2011 | 04:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
First thoughts are fuel delivery (fuel pump or fuel filter, or both), or ignition (spark plugs, spark plug wires, distributor cap, rotor, coil, etc.).
Old Mar 9, 2011 | 04:14 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: new guy needs help, tpi breaken up on top end...
Check fuel pressure, at idle and throughout rpm range, you are gonna have to look up specs, as I cannot remember where it should be , 48-52psi seems right, but I'd double check that. If low, I'd do like James says, fuel filter, then the pump next.....
Old Mar 10, 2011 | 11:17 AM
Guest
Guest
Posts: n/a
afternoon all,
updates:
car seams to be doing a tad bit better now...mabye alil faster than what it was just a week ago...mabye this cold air plus the new 180 stat? ^_^
did a freeway pull and the problem started happening around 4K in third, also 2nd mabye ALL fine as well.....my buddy will look at this evening.
-Also I had a full tune up (everything, the mech was a geard head as well and got me a discount ^_^)
this was 12/x/2008 so....I shouldnt need another 1...hmmm-
--wheir was I?....dont remember.
---Guess thatll be all for this up date
----Pat
P.S. cant wait for th weather to turn around and my other buddy to get done with that BIG TPI!!!
Old Mar 10, 2011 | 11:39 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
wheres da pics..........
Old Mar 11, 2011 | 01:35 PM
Guest
Guest
Posts: n/a
what pics?
Old Mar 11, 2011 | 01:58 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Put a fuel pressure gauge on your shrader valve, tape it to the windshield and check the FP under load
Or tape a friend to the hood and stick the gauge in his mouth so it faces you.
Old Mar 11, 2011 | 02:04 PM
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
i wont tell anyone who you are.... i had a similar problem it was bad plug wires fine at idle but under a load started misfiring. check for stray arcs under the hood at night
Old Mar 11, 2011 | 02:12 PM
Guest
Guest
Posts: n/a
ok, mabye im confused.....
Any ways my buddy put it on a scan tool and he said it was fine, but when I did another back roads test and the problem is still their in 3rd....
Old Mar 13, 2011 | 03:20 PM
Guest
Guest
Posts: n/a
Did a bunch of runs and its still doing it...like a back fire or something, 2nd gear wot around 4500 and in nearly all of third...he will look at it when were both free.......DANG IT!!!
customblackbird
Aug 15, 2021 10:16 PM
jharrison5
Aug 19, 2015 05:53 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Sanjay
Aug 12, 2015 03:41 PM
