Gas Gauge and More $$$
Old Mar 10, 2011 | 05:31 PM
Guest
Guest
Posts: n/a
My gas gauge always goes to full even if i have no gas. How can I fix this??? Also where is the sensor in the tank located and whats the easiest way to change it out with a new one?
Also, the needle for the temp jumps all the way past high on start up and I have to tap the needle to get it back to normal... Why does it do this? My cousin said that he put in a wrong car battery and it over regulates the system making it do that and causing the fuel gauge to go out of wack?>??
Please let me know what your thoughts are..
Old Mar 10, 2011 | 06:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Gas Gauge and More $$$
Battery has nothing to do with it, as long as it's a 12v battery.
Sounds like you have a dash connection loose, maybe a ground.
Old Mar 10, 2011 | 07:13 PM
Guest
Guest
Posts: n/a
Loose ground? Could u be a little more specific, not sure where to start looking.
Old Mar 10, 2011 | 07:18 PM
Guest
Guest
Posts: n/a
I don't know much on electrical could u help a lil more plz
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
