Occasional No start...why?
Old Mar 13, 2011 | 08:26 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Occasionally when I turn the key, all I get is power from the battery for the radio lights horn and all of that. Which works fine, but when I try to start it, I get nothing. The fuel pump doesn't do anything, and the starter doesn't do anything at all. It happens at weird moments too. It happened yesterday, so I got out and got a new key I had made and it worked. Then I tried the original key again and it worked. I have no clue what causes this.
Any ideas?
Old Mar 13, 2011 | 08:28 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Occasional No start...why?
With your 92, it could be a bad VATS. Might be something wrong with the old keys chip, like not always making contact, causing no-start.
Old Mar 13, 2011 | 08:30 PM
chevydrvr's Avatar
I just think it's weird that once It worked with a new key, the old one worked again no problem.
Old Mar 13, 2011 | 08:34 PM
Car: GTA
That is why I said the old not always making contact. New one isn't worn so always work. Old one sometimes touches, sometimes not.
Just bypass the VATS completely & never hafta worry about it again. New keys/spare keys are much cheaper too.
Old Mar 13, 2011 | 08:43 PM
chevydrvr's Avatar
Alright thanks, I'll search around on how to do that.
Old Mar 13, 2011 | 08:56 PM
Car: GTA
The cheap resistor bypass will work only if the VATS Module is still working. It is simply a resistor put inline, to trick the Module into thinking that the correct key is being used.
The "fancy" box totally eliminates the Module, which is good for when a Module goes out & the resistor trick no longer works.
https://www.thirdgen.org/forums/sear...archid=3883919
Old Jun 9, 2011 | 09:49 PM
sandiegobird's Avatar
Car: 92 Firebird Formula
Engine: 5.0 TBI
can the vats module be bad even if a new key is made and the idiot light goes away but still nothing? i got a thread going if you need more info.
eightsixseven
Dec 16, 2024 01:50 PM
gta892000
Aug 11, 2019 11:16 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
Grant2k
Apr 4, 2016 08:21 AM
jrdturbo
Mar 31, 2016 02:58 PM
