Throwing away M-55HV where to go now?
Old Mar 14, 2011 | 10:21 PM
cprepared125's Avatar
Car: 85 Z28 scca C Prepared
Engine: 5.7 348 RWHP
Transmission: t5
Axle/Gears: dana 44 3.41
OK so just built a new 350 for my autocross car but after the first few races realised the high volume pump was sucking the pan completely dry. The bearings are barely broken in and they have a farely loose .0035 clearance. so do I go M-55 or M-55A 30wt oil, 40wt oil? any other suggestions. Motor made 348hp and 331 tq at the wheels rev limited at 6500 and hits it on a regular basis
Old Mar 14, 2011 | 11:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Throwing away M-55HV where to go now?
I run a standard low volume pump in my engine. It provides 70 psi at 7400 rpm.
Nobody really needs a high volume pump for that exact reason. At high rpms, it will suck the pan dry. A standard pump will provide more than enough oil.
Old Mar 14, 2011 | 11:22 PM
Transmission: t5
Standard volume and standard pressure? so basically melling's more expensive version of the m55?
Old Mar 15, 2011 | 07:15 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Standard volume but the higher pressure spring in the pump.
Old Mar 15, 2011 | 08:25 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I used the yellow standard pressure spring in the M55HV oil pump. http://www.youtube.com/watch?v=tOiHd...eature=related http://www.youtube.com/watch?v=7IpJl...eature=channel
Fanatic1074
Oct 3, 2022 05:57 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
Bigold4x4
Sep 28, 2015 05:21 PM
ndndndnd
Sep 28, 2015 08:00 AM
