Operation: Investigate Knock!
Old Mar 16, 2011 | 02:40 AM
Countryguy's Avatar
Car: 91 Camaro RS
Engine: 383 Stroker Built
Transmission: Turbo 350
So I bought my camaro last year with a slight tick, drove it for a bit and it got worse. So I fixed my truck so I could drive it, and then I decided to start working. It sounded like it was a lifter tick. So I pulled the intake manifold and decided to take a look. OH BOY did I find something, the PO had to different length push rods in there, he had 7.950 in cylinder 6 which is were I heard the tick, bought new push rods and why not do the lifters so I bought those as well. Put it back together fired it up, GREAT still a knock or tick . So I stripped it down to see if I could find anymore evidence on whats making the knock. I pulled the heads and this is what I found!Operation: Investigate Knock!-101_0023.jpg
Operation: Investigate Knock!-101_0024.jpg
Operation: Investigate Knock!-101_0028.jpg
After seen this it looks like I have more work to do!
Old Mar 20, 2011 | 12:19 PM
Countryguy's Avatar
Car: 91 Camaro RS
Re: Operation: Investigate Knock!
Found more out today, I have the motor completely torn apart. I have a comp cam XE262H, SCAT crank and connecting rods, and Claim pistons.
I got more pictures too.
Operation: Investigate Knock!-101_0046.jpg
Two more cracked pistons.
Operation: Investigate Knock!-101_0052.jpg
Shattered skirt.
Operation: Investigate Knock!-101_0059.jpg
Found the skirt pieces in the oil pan!
Old Mar 20, 2011 | 01:00 PM
torque_is_good's Avatar
WOW
I hope anyone who even considers buying a used or junker engine to just drop into their car will look at this. Yes, you bought the entire car but there is so much crap out there, and with the age of these cars, you really need to be able to budget a teardown/rebuild unless the seller has good documentation of the rebuild they performed.
How are the cylinders? Is it sleeving or new block time?
Old Mar 20, 2011 | 01:09 PM
Countryguy's Avatar
Car: 91 Camaro RS
The bores are very smooth, I have one groove in the #4 cylinder but im pretty sure I can smooth it out. Im glad I took it apart thou, to see what I had in there, Im going to take a micro to the crank and cam see if there still good, they sure look like they are. I hope there ok, that scat crank is a little pricey!
Old Mar 20, 2011 | 06:53 PM
Countryguy's Avatar
Car: 91 Camaro RS
More Pictures!
Operation: Investigate Knock!-101_0047.jpg
Operation: Investigate Knock!-101_0055.jpg
Operation: Investigate Knock!-101_0056.jpg
Old Mar 20, 2011 | 06:58 PM
Countryguy's Avatar
Car: 91 Camaro RS
Operation: Investigate Knock!-101_0054.jpg
Operation: Investigate Knock!-101_0053.jpg
SCAT rotating assembly, Comp Cams XE262H cam, all going to be checked to see if there still in spec, pricey if there not, lets hope they are!
Operation: Investigate Knock!-101_0050.jpg
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
