Identify a single wire?
Old Mar 16, 2011 | 12:09 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
I'm losing my mind over one single wire that I can't seem to figure out what its for. 1990 Camaro, this wire is in the same location in my TBI harness and TPI harness. Its a single dark green wire with a flat connector, comes out on the drivers side of the engine. The closest wire that comes out of the loom by it is the purple oxygen sensor wire. I had labeled it as "knock sensor" but thats wrong, I'm guessing it was some sensor screwed into the block though. I can't find anything for a dark green wire in the service manual.
Any ideas?
Old Mar 16, 2011 | 12:18 PM
Re: Identify a single wire?
Temp gauge sending unit; driver's side head, between #1 & #3 plugs
Old Mar 16, 2011 | 12:46 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
... Guess I can stop thinking my gauge cluster is broke because the temp gauge doesn't move
Thanks!
Old Mar 16, 2011 | 01:58 PM
Exactly... see my signature.
Old Mar 16, 2011 | 02:09 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
That was easier than a Dallas cheerleader on a Friday night after a 12pack of beer!
Old Mar 16, 2011 | 03:45 PM
torque_is_good's Avatar
also known as the wire that's missing from my harness
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Redwhisper
Aug 26, 2015 05:02 PM
Linson
Aug 21, 2015 02:12 PM
overdriv
Aug 20, 2015 03:52 PM
Street Lethal
Aug 14, 2015 08:25 PM
