How to Open Steering Column..?
Old Mar 19, 2011 | 06:02 PM
nezzie09's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 2.8 MPFI
Transmission: 5-Speed Standard
I'm installing my remote start/alarm on my standard transmission and need to know the best way to remove plastic around the steering column..
Old Mar 20, 2011 | 04:43 PM
EFF26's Avatar
Car: 1991 firebird
Engine: lo3 305 TBI
Re: How to Open Steering Column..?
Not the best idea to do on a stick shift. It might take off if your careless. I don't think you can remove the plastic. Unless you mean behind the turn signal. But I'm no expert.
Old Mar 24, 2011 | 10:06 PM
nezzie09's Avatar
Engine: 2.8 MPFI
I figured it all out. And it's fine, i bought one that's compatible. You can set it to automatic or manual trans through the installer features and when set to manual the operator is required to push the brake, apply e-brake, let go of brake, click the valet switch twice then remove keys from ignition and exit car. The car continues to run until the alarm is armed via remote. The vehicle can now be remote started at any time UNLESS the vehicle is entered(alarm disarmed). So even if a friend drove my car and left it in gear, then i tried to remote start it, it would do nothing.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
