HELP,WIRING NIGHTMARE!!!!!
Old Mar 19, 2011 | 09:42 PM
emilde's Avatar
Car: 1986 pontiac trans am
Engine: 305 t.p.i (for now)
Transmission: 700-r4
I have an 86 trans am with a carbed 305. the previous owner replaced the engine wire harness with one from a tuned port car. I fond the coil wire got it hooked up, reached in and started it up and all seemed good untill i went 2 shut it off.... turned key off and motor kept running,the only way to shut the car off is to unplug power wire from coil. even with the distributor and alternator unplugged and the key off the following stay on: amp guage shows battery voltage turn signals work and the check engine light is still on,i have power every place i SHOULDNT!!!! so far everything is pointing 2 the ignition switch but ive replaced it and it still does the same thing.... any help would be great because as of now im completly out of ideas!!!!!!!!!!!!!
Jorlain
Aug 24, 2022 05:11 PM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
