engine code
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: engine code
Heads could also be aftermarket Vortec ( 8 bolt ) heads from China
880 block is the one used for the Fastburn engine but is also used for most GMPP crate engines
and millions of Vortec truck engines as well
Re: engine code
Could be; nothing you have said so far "proves" that it is, but nothing "proves" that it isn't, either, so it isn't ruled out yet.
Get the head casting #s. That's the "proof", nothing else will do.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: engine code
10243880 is teh same casting number on the 350 I pulled from a 98 silverado for my 355 engine build. It is a roller motor, but without knowing more about what's done to the motor, it's hard to say.
Car: 82 Z28
Transmission: T400
