91 Camaro surging when warm
Old Mar 21, 2011 | 03:24 PM
scaggsj's Avatar
Car: 1991 Camaro RS
Engine: 3.1L
Axle/Gears: Stock
Hi,
Got a 91 Camaro rs 3.1L V-6 with the 4speed auto.
Heres the deal starts and runs great when cold. Once it gets to 210/220 it starts surging at idle and sometimes will die. Cruising down the highway while its warm it is fine. Just when you come to a stop sign it starts surging real bad.
EGR?
Old Mar 21, 2011 | 04:38 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: 91 Camaro surging when warm
vacuum leak
Old Mar 21, 2011 | 07:26 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
maybe egr
Old Apr 1, 2011 | 02:55 PM
scaggsj's Avatar
Car: 1991 Camaro RS
Engine: 3.1L
Axle/Gears: Stock
How would you go about checking to see if egr is any good?
Also, hdis2002 Ive sprayed carb cleaner around while it was running and no go there. But it was cold and it only seems to do this surging after it warms up. What kinda vac leak would only show up when warm?
Old Apr 1, 2011 | 04:05 PM
azfirebird's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7l
Transmission: 700r4 New Rebuilt 2011
Axle/Gears: 9 Bolt
The other thing to have checked is the Injectors. I just had mine in for similar things and found once the injectors got warm 2 of them failed. But i also had start up issues that once i started the car turning it off right away it would not start. I am going to replace the injectors this week or so.
Old Apr 2, 2011 | 01:20 PM
scaggsj's Avatar
Car: 1991 Camaro RS
Engine: 3.1L
Axle/Gears: Stock
Thanks, Ill check them, but mine will start right back up after it dies. I never have a starting problem once it starts. On occasion it might take a couple cranks to get it to start but once it starts it fires right up every time after.
On the injectors you just checked voltage or pressure to find out you had an issue?
Old Feb 9, 2015 | 11:15 AM
68blackbird's Avatar
I had a lady friend that purchased a new 91 V6 Firebird new in 91. She would complain of surging but they always said they could not duplicate. It surged on me so I finally got a face to face with a regional rep. He came to the Pontiac dealer in Rockville Maryland and took a new PROM/chip and reprogrammed it and put it in the car in front of me. The car performed much better and never surged again. I could never get a definitive answer. End
jbd1969
Aug 17, 2015 07:06 PM
stalkier
Aug 13, 2015 12:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
