Broke Down today, Need advice
Old Mar 23, 2011 | 04:17 PM
Curtis7e's Avatar
Car: 85 Camaro Z28
Hello,
Today i was driving home from work, i was doing about 45 MPH and my engine just stopped responding. It was still running but when i gave it gas it wouldn't really accelerate. I got it off to a parking lot and hopped out and gave it gas from the throttle and the engine would rock a little like it was trying to rev up but ultimately wouldn't rev. I turned off the engine and tried to look at everything i could. Everything looked in place from what i could tell, I don't have that special mechanic's eye and plus is was kind of paniced on the side of the road. I tried and tried to restart the engine would turn and turn but never start. I kept trying and it finally started but it had the same effect, give it gas and nothing really happened. I let it idle like that. after about a min it just died out. I let it sit for about 5 mins and then tried to start again after the 2nd try it started up and was acting normal. I got in and started driving it had a bit of hesitation on accelerating but ran fine other than that. When i parked the car in my garage i could smell fuel. I'm thinking that its some kind of fuel problem i just need some advice where to start.
This past weekend i replaced the Distro cap, roter and spark plug wires. Monday and Tuesday the car drove great. today it did this to me.
Thanks for any help in advance!
Old Mar 23, 2011 | 05:19 PM
Curtis7e's Avatar
Car: 85 Camaro Z28
Re: Broke Down today, Need advice
quick update.
After i got home and let the car cool for a while i went out there to check the fuel pressure. I hooked up the gauges and got about 42 lbs with the car in the on postion. I started the car up it lowered and stayed steady at about 33 to 33 lbs.
While it was idling i was hearing a tick, tick tick tick sound. I watched the Tachometer every time it ticked the tach would drop. I turned off the car popped off the distro cover and saw that a spark plug wire had popped off i reconnected it and started it back up no more tick sound.
guess my question now is could that have caused my symptom above? thanks!
Old Mar 23, 2011 | 11:40 PM
david chambers's Avatar
Car: 1986 iroc Z-28
Engine: "LB-9" TPI 305
Transmission: 700-R-4
Axle/Gears: corporate 2:73-1
i have seen this since the 70s there is a wire retainer on 86 and older HEIs it keeps the wires from....popping off the cap.find one. and be happy
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
mrdevontay
Sep 2, 2015 08:04 PM
